1986 911 Carrera seats in a 1981 911 SC Targa
Dear All
Since one week, I am an owner of a 1981 911 SC Targa. I am already obsessed and have become completely unproductive in all other things in my life, spending hours just standing there looking at it, driving it and searching for things on the internet about it. Photo attached. Btw the red Citroen 2CV in the background is mine also. I have searched threads for a response to the following very specific question and have not found a response that I am confident completely answers the question. The seats on my car are in pretty bad shape. I have found two seats from a 1986 911 Carrera that are in excellent condition and before I fork out the money for them, want to be sure if there is any reason why I would not or could not use them in my car. Thanks for your thoughts.
They will bolt right in and work perfectly. If they are electric and your current seats are not, you will have to route power to them, but that's a piece of cake. I have '86 944 seats in my '83 SC now (bolt right in) and have a like new pair of 993 seats ready to go in and replace those (more modern and in like-new condition). There is great interchangeability with seats in 911 up to and including the 993. Starting with the 996 (1996 onwards) things changed and they were no longer compatible with the older car like ours.
'83 911SC, '99 986, '15 991.1 GT3 |
Thank you brad951. Guess what I will be doing this weekend...
Uncertifiable!!!
Hmmmm.........if an ‘81 SC has the same rail base as a ‘78, then ’86 electric sport seats do not fit directly. You will have to drill new holes and if you decide to use the seatbelt receptacles attached to the seats (as opposed to the receptacle base on the tunnel), you should reinforce the rail bases closest to the tunnel. Also, you will sit approximately 2.5 cm higher-may be an issue if you are tall.
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 06-09-2018 at 03:56 AM.. |
I got the whole interiors for my 1980 SC. Electric seats fit and work perfectly
Paolo from Alps 1980 911 Targa SC 3.0 - Silver metallic 1980 Ducati Pantah 500 - Red 1989 Yamaha 500 "Tracker"
I continued to use the floor mounted seat belt receptacles, and removed the ones that came mounted on the '86 944 seats.
Guys how about for an older car...What later seats will fit my 66?
adam912 Out '66 912, 2.2L T4, 5 speed, S suspension, woo hoo! |
You need adapters to put 74 and later seats into an early car. Rob
Wasn't there one year of 3.2s that had a different seat mount?
'80 SC Targa Avondale, Chicago, IL |
