Originally Posted by darrin View Post
Sherwood -- believe that's the knob for a dogleg pattern 901 box -- OP has a later 915 box
Thanks for the correction. They're cheaper. Take a whack at it.
Old 06-13-2018, 04:50 PM
Jp-oh's Avatar
Any ideas on how to remove in a Carrera with the leather boot? There is no room between the leather boot and the knob to fit a wrench. I could get a wrench under the ball part of the knob but I feel this will 100% damage the knob by scoring or denting it.
1986 Meteor Grey Carrera
Old 06-18-2018, 05:46 PM
TheSt|G's Avatar
Originally Posted by universeman View Post
That's good info for folks here to have. Pelican / Suncoast ship you a different part than what's shown. Go to the dealer if you want the one sugarwood posted!
Could also be the dealer had NOS on the shelf.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 06-18-2018, 07:11 PM
Jp-oh's Avatar
Aaaannddd the knob is destroyed.
Old 06-19-2018, 06:37 PM
Functionista
manbridge 74's Avatar
Late I know but Carrera knobs are screwed down from the top I think.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-19-2018, 07:55 PM
Jp-oh's Avatar
87 and up are. 86 and below by simply massive amounts of friction.
Old 06-19-2018, 07:56 PM
joefrantz's Avatar
Rubber strap wrench works great. Plenty of leverage, no bludgeoning with hammers and wrenches. No damage to knob
https://www.amazon.com/ARES-Universal-Non-Marring-Adjustable-Resistant/dp/B06VSSFPYB/ref=sr_1_2_sspa/140-8061931-6167521?ie=UTF8&qid=1529462204&sr=8-2-spons&keywords=strap+wrench&psc=1
Joe Frantz
73 911 T
Old 06-19-2018, 07:57 PM
gtc gtc is offline
abides.
gtc's Avatar
This is the traditional method:
1. Get an ice pack from the freezer before starting.
2. Try to position yourself directly over the shifter.
3. Pull up on the shift knob with both hands, as hard as you can. When you have exerted your maximum force on the knob, it will release easily.
4. Apply ice pack to whatever part of your face you just whacked with the shift knob.
Graham
1984 Carrera Targa
Old 06-19-2018, 08:06 PM
Lol perfect. I saw that coming(not the shift knob unfortunately)
Old 06-19-2018, 08:52 PM
Flojo's Avatar
It won't come off even hitting/chiseling it?!
Well, probably a PO has epoxied/glued it.
Wouldn't the first time, that a PO chose this "quick" method instead of using a new chrush ring.
If you do not want to destroy it, I recommend you take the whole lever unit off the tunnel, place it on a bench upside down, dribble some glue solvent inside and keep trying knocking it off.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 06-20-2018, 06:56 AM
I got the new boot and I’m willing to take the whole thing out.
I do have a feeling it is glued.
1976 911s targa
Old 06-20-2018, 04:47 PM
wayne robson's Avatar
shift knob removal
Hi , it will come off, even if is glued, .
Do as John Walker said ,but try this while doing it.
You have to have the best tools and Chanel pliers are the best there is
buy 12 inch pair you will never regret it, place a old piece of leather around
the shift knob at the fattest part of the knob, rough side of leather to the knob,
now you still might mark the knob a little but most times with leather it wont mark,
now adjust the chanels to the correct gap,and give it all you got counter clockwise
incase its threaded,it will be off first go.
Old 06-20-2018, 06:02 PM
