Shifter knob removal
I am doing sound deadening on my car, as I donít plan to our carpet just mats, and found really hard to remove the shifter knob so I can install the new shifter rubber boot.
I hammered pulled pushed damaged the knoe at the bottom but no go.
How can I remove this knob?
Are there any other alternatives to factory rubbber boot?
I donít mind this shifter exposed but with the boot looks better.
Before:
After:
1976 911s targa
Old 06-06-2018, 04:01 PM
You take an appropriate sized wrench and put it under the lip on the knob. Then use a rubber or plastic hammer to gently but firmly strike the wrench handle under the knob and it will pop off. If you twist and pull hard enough it will probably come off too. Mine was stuck pretty good. There's a metal friction "ring" I'll call it holding the knob to the shaft.
Old 06-06-2018, 05:22 PM
newbie
mats look good :-)
Old 06-06-2018, 06:14 PM
Originally Posted by 7783911 View Post
mats look good :-)
They do, thank you.
1976 911s targa
Old 06-06-2018, 06:26 PM
Exactly what gazzerr said. Have a new crush ring ready. I tried to reuse the old one and one day the knob came off in my hand when I shifted into second. Got a new crush ring, no problem.
Old 06-06-2018, 07:30 PM
I had the shifter out on a bench and hit the wrench multiple times with no luck, this is the knob facing downward.
MIT damaged the knob at the bottom and any more force would probably shatter the plastic.
To me feels like the crush ring is rusted inside.
1976 911s targa
Old 06-07-2018, 04:06 AM
Some of them just won't come off. Destruction by channel-locks is the only alternative if it really needs to be removed.
206 637 4071
Old 06-07-2018, 04:13 AM
Functionista
manbridge 74's Avatar
Take the shift shaft out and slide boot up from bottom. This type of knob can be a pain to remove without destroying it.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-07-2018, 04:16 AM
Did what you are trying to do last week. Also had the hole shifter out and in the vices upside down. I put a pice of tape on so i could see if it startet to move. Added a 15mm wrench over and hitted i several times with a heavy hammer, and i got it lose. It is not easy to hit it straight but make sure i is stable when you hit it and it not turns.
Old 06-07-2018, 05:09 AM
i've read that applying some heat can help too (but not enough to melt the plastic knob) -- You will destroy the shift knob once done
Old 06-07-2018, 07:02 AM
What manbridge 74 suggested.
Remove the entire shift housing assembly; remove the pivot pin and slide the shift lever from the top. Then slide the shift boot onto the lever from the bottom. You still have to maneuver the boot over the lower lever bits. In this way, you won't damage your shift knob. To reinstall the factory pivot pin, use a longish drift punch to align the pivot pin holes in the shift box and lever. Clean the areas and sparingly apply waterproof bearing lube to friction areas.
If it's too late to save the knob, just remove the remnants and order a new knob (factory or aftermarket). The existing crush sleeve may still be serviceable and maybe not create such a permanent bond.
Sherwood
Old 06-07-2018, 10:48 AM
proporsche's Avatar
i`m with manbridge74 idea ...kava do not damage the knob any more, they are pretty penny now...
Ivan
1985 911 with original 491 115 miles..790 372km.
Old 06-07-2018, 12:56 PM
universeman's Avatar
I had to destroy mine to get it off. The replacements are not the same (they have a shiny printed top under plastic as opposed to the shift pattern imprinted in the knob like yours.)
Fortunately I found a NOS one from someone on here.
Jason - Austin, TX
82 911 SC targa
Old 06-07-2018, 01:38 PM
sugarwood's Avatar
Not true.
https://tinyurl.com/ybnbuw35
1986 3.2 911 coupe.
Old 06-07-2018, 01:54 PM
Early shift knobs are smooth, shiny black plastic, and expensive. Careful taking it off.
part number: 90142401400
Sherwood
Old 06-07-2018, 03:53 PM
Sherwood
Sherwood -- believe that's the knob for a dogleg pattern 901 box -- OP has a later 915 box
Old 06-07-2018, 03:59 PM
Immature Member
dentist90's Avatar
I accidentally chipped the base of the knob trying to tap it out. More like a chunk actually. At least it let the crush ring go at that point but ended up ordering a new one. Regardless, one thing to consider is that a PO may have used epoxy instead of or in addition to the crush ring. Thatís a whole other kettle of fish. If you see glue between the knob base and the shift shaft this may be the case.
Old 06-07-2018, 04:22 PM
Originally Posted by sugarwood View Post
Sugarwood, I ordered that part, from Suncoast, and I got the shiny/clear plastic top one. This was a few years ago. Put that same part# into our host's search box, and you'll see the one you get when you order it. I thought I was getting the one in your picture, but I didn't.
Jason - Austin, TX
82 911 SC targa
Old 06-13-2018, 02:42 PM
sugarwood's Avatar
I got mine at the dealer. Like in the photo
1986 3.2 911 coupe.
Old 06-13-2018, 03:21 PM
That's good info for folks here to have. Pelican / Suncoast ship you a different part than what's shown. Go to the dealer if you want the one sugarwood posted!
Jason - Austin, TX
82 911 SC targa
Old 06-13-2018, 03:26 PM
