Upon cold start up and going into reverse gear, I am grinding. I count 5 seconds before shifting. Clutch seems to not disingage during this time. After warmed up, not problem. No clutch slip or shudder when warm. Possible oil on disc from leaking rear main oil seal? or tranny problem? I also have to ease into 1st gear when warm or grinding occurs. 81'SC
[This message has been edited by lagoon (edited 11-05-2001).] |
I have a similar problem with mine. As was explained to me, 915 gearbox does not have synchos in either 1st or reverse. I find that upon cold start up, if I shift into 1st & 2nd and then into reverse, no grinding.
Also, check to see when your last transmission fluid change was. I changed mine (swepco) and problem improved markedly. ------------------ Steve '85 911 Targa |
No synchro is first? there has to be. this is the first to go out is it not?
There is a syncro on first, but it dosn't work very well. This also is migrated be the effect of having to eather reverse rotation of the input shaft, or having the largest diference on gear ratio in the transmission.
------------------ Ted Stringer nuke3@juno.com '84 911 Targa aka pocketrocket |
they work fine when they're in good condition.
high cold idle makes reverse harder to engage quietly. you could try adjusting the clutch a bit tighter. |
I have the same problem sometimes, so I shift into 2nd or 3rd before I try reverse or 1st again. It usually works.
Keep the rpm's up when cold shifting it helps. Steve |
Are you CERTAIN that your clutch is adjusted properly with 15-20 mm of freeplay?
Grinding in reverse is usually indicative of a maladjusted clutch. ------------------ Warren Hall 1973 911S Targa 1992 Dodge Dakota 5.2 4X4 parts hauler [This message has been edited by Early_S_Man (edited 11-05-2001).] |
Guest
Posts: n/a
Have you tried if it helps holding the clutch down while starting the engine?
My dad's Volvo grinds when selecting reverse just after starting the engine without pressing the clutch down. If he holds the clutch down while starting the engine reverse can be selected without problems...? |
