Senior Member
Superman's Avatar
Wonky Exhaust
One of the two SSI exhaust pipes, which run outside of and along side the SSI sheet metal, and which have flanges at the end and bolt to the final exhaust (muffler) hangs down further than the other one. As you can see from the photo, this causes the muffler to not sit exactly horizontally. The problem is not with the muffler flanges. The problem is with one of the fat pipes on the SSIs. The left one bends downward, though I cannot see evidence of trauma. Do you think someone might have sufficient skill to heat and bend this upward about a half-inch without having to remove the heat exchangers?
Mocha 1978 911SC. "Coco"
Old 06-09-2018, 11:10 AM
Senior Member
Superman's Avatar
Let's try that again.
Old 06-09-2018, 11:12 AM
