| Mike P |
			06-09-2018 12:59 PM |
			New guy here with a tail light problem.
		I just recently purchased my first Porsche, an '80 SC and am having some R side tail/brake light issues.  The R rear side running light works, turn signal work, reverse light works but the brake/tail light doesn't.  Ive replaced the bulb, checked the fuse, disassembled and cleaned the contacts, still nothing.  While I had the tail light assembly apart I tested everything and it all worked, put it back together and back to no R tail/brake light.  Unfortunately I'm at work and don't have a volt meter with me so I can't check anything that way.  Does anyone have suggestions, is the bulb holder in the housing faulty, is the housing not grounding appropriately, etc...?   I'm kind of at a loss.  Thanks in advance for any help or suggestions.
