rokemester's Avatar
Exhaust R&R
Many share trials and tribulations with frozen and broken exhaust studs. Anyone besides me get the urge to make sure the fasteners donít get frozen and broken when you want to remove it for whatever reason. The Allen fasteners come out pretty easy with the engine in car, the 13mm nuts are a different story. They are tricky to get a nice grip. Suggestions, besides leaving well enough alone??
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
2016 BMW 328i
Old 06-10-2018, 07:34 AM
Not sure how you would make sure they don't get frozen without taking them off in the first place. Use some copper antiseize when the nuts are off and it will be easier the next time. If you don't need to have the heat exchangers off I'd leave them alone until that time
You need a "wobble" socket to get the 13mm hex nuts.
Like this.
_______________________________
1982 911 SC 230,000mi and counting
Old 06-10-2018, 08:34 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
anti-seize!
Gordon
'71 911 Coupe 3,0L outlawed
Old 06-10-2018, 09:56 AM
rokemester's Avatar
Thatís what I want to do is make sure there is good anti-seize on the studs. Figure if I bust them loose every now and again Iíll avoid the headache in the future. OCD yes, but is satisfying to be able to crack them without shearing off the stud. Thanks for the wobble socket tip. I donít have those in my tool box.
Old 06-10-2018, 10:35 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Try nickle anti-seize, it has higher temp rating
'85 Carrera Targa
PCA/POC
Old 06-10-2018, 12:06 PM
Chain fence eating turbo
We used this on military jet engines. The area got to around 3-3.5k degrees F.
If itíll hold up there, itíll easily hold up on our motors.
Old 06-10-2018, 01:03 PM
Surely the extra 600F of the nickle based anti-seize above the 1800F (!) temperature rating of the Cu based product is overkill in this application, ignoring the other differences for the sake of the argument.
But hey, I totally understand the urge to splurge on our beloved engines when it's only a few bucks extra.
I can't afford that.
Old 06-10-2018, 01:50 PM
I just took the last of mine off today. 12 for 12 no broken studs. I got to all 6 hex nuts with the 13mm socket I attached a picture of a 10" extension and small breaker bar. For the barrel nuts I cut off a long 8mm Allen key and used it with a 8mm socket through the access holes in the exchangers. I think if you get them off once and load them up with anti-seize you'll be good forever.
Old 06-10-2018, 09:17 PM
rokemester's Avatar
I used a standard L Allen wrench with a cheater bar, nice and easy cracked all 6. Would like to see your pic with the 13mm socket. Was your engine in car? The left side with cat and guard installed is tight.
Old 06-11-2018, 02:36 AM
1988 Carrera
shadowjack1's Avatar
OCD, yes. I check and loosen mine every oil change. I even apply more anti-seize thread lub. High temp copper formula, good to 2000F.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 06-11-2018, 05:13 AM
rokemester's Avatar
Oh THANK YOU good to know Iím not alone! Whatís your favorite fastener attack scheme?
Old 06-11-2018, 05:48 AM
1988 Carrera
I use an off set wrench Works very well..
88' Carrera
75' Targa gone
72'914 gone
72' 914 gone too
Old 06-11-2018, 06:23 AM
rokemester's Avatar
13mm offset wrench did the trick. 5 out of 6 came off stud and was able to reinstall with copper anti-seize. One nut and stud came out as one piece. Now soaking in penetrant. Thanks all!! Like idea of doing this when changing oil.
Old 06-12-2018, 03:22 AM
theiceman's Avatar
the advantage of the cut off 8mm in the 8mm socket is that you can put a torque wrench on when putting it all back.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-12-2018, 07:27 AM
theiceman's Avatar
why on earth would you put this back ? that is the perfect situation . Put in a new shiny stud and nut !!
Old 06-12-2018, 07:29 AM
rokemester's Avatar
Word!
Old 06-12-2018, 07:31 AM
theiceman's Avatar
IMO there is no such thing as overkill when dealing with studs into the head. Do absolutely everything you can to ensure they wont break on removal.
theiceman's Avatar
I just finished my exhaust project so I know exactly where you guys are coming from .
Old 06-12-2018, 07:38 AM
Good work!!! It's quite a relief to get them all off. It may be easier/safer to just cut off the stubborn nut now that the stud is out of the car.
Looks great. I can't wait to get my SSIs and M&K installed. I'm going to have to delay my gratification, I've got some partially crushed oil lines that need attention, a dirty engine and a valve that needs adjusting. At least the old exhaust is off with all 12 studs intact.
Old 06-12-2018, 08:55 AM
rokemester's Avatar
Found these today at Euclid Foreign while trying to find an exhaust stud. About the same height as the Allen nuts, more to grab onto in the future. Generous amount of copper anti-seize.
Northeast Ohio
1966 VW Beetle, 6V
2016 BMW 328i
Old 06-12-2018, 08:24 PM
