irl irl is offline
irl's Avatar
Send a message via AIM to irl
Dont shred your door strikers.....
They are not an Allen Key and they are not a Torx bolt, they use an 8mm "triple square socket". Bolts come preloaded with lock tite so they are a ***** to get out if you strip them and you will without the right tool.
Eddie from Baltimore
74 911 under construction searching for its new identity
75 911 backdated RSR widebody on its way
71 911T running sweet
63 356 outlaw frustrating purists
Old 06-12-2018, 07:08 PM
Thanks. I'm getting ready to replace mine. Host sent me the replace me recently but I better check the tool chest for the right fit.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles
Old 06-12-2018, 08:10 PM
911 enthusiast
Iíve also seen these called XZN sockets. They take the door strikers off easily when attached to a moderately-sized breaker bar. Pro tip I saw on here: undo one bolt entirely, loosen the other - but leave it screwed in for a moment. Swivel the door striker out of its own way and put the first bolt back into the empty hole. Then remove the other bolt and youíre holding the striker in your hand without risking some kind of backing plate sliding around inside the door frame.
Old 06-13-2018, 04:24 AM
The Mighty Pieholio
Bob Kontak's Avatar
There must be good smoke in Kerville.
A set of them are pretty cheap from the auto parts store. I have seen them (fasteners) on newer VW's.
Napa sells a much higher quality set. KD, I think. You pay for them.
1981 911SC Targa
Old 06-13-2018, 05:32 AM
Shaun @ Tru6's Avatar
Good post Eddie!
Tru6 Restoration & Design
Old 06-13-2018, 06:51 AM
4flyboy's Avatar
That's a land mine waiting on the trail, thanks IRL !
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 06-13-2018, 07:40 AM
I replaced mine last year after seeing the plastic was broken inside. These are not something that you'd normally associate as a wear item.
'66 912 - Polo Red;
'74 911s - Silver Carrera RS clone
'77 911s - Peru red IROC Clone
'89 964 C4 - Guards red
Old 06-13-2018, 07:41 AM
universeman's Avatar
There's a kit to replace the plastic inserts.
Jason - Austin, TX
82 911 SC targa
Old 06-13-2018, 08:17 AM
theiceman's Avatar
Red Loctite ? holy crappers.
yeah those zxn or " triple square" are used all over my audi too.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 06-13-2018, 08:21 AM
Even a Bad day is good
47silver's Avatar
kit for replacement
where do you get he kit to replace the plastic?
1975 911S Targa
Silver Anniversary Edition
Old 06-13-2018, 12:19 PM
Scroll down a little
https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=door+striker
Old 06-13-2018, 12:21 PM
SIC-531-701-31 is the part number for the rebuild kit.
Jason - Austin, TX
82 911 SC targa
Old 06-13-2018, 01:13 PM
'73 911 T Targa
Wow, lots of great advice here. I got new strikers and had planned to do the job with a Torx. You guys saved me from. Disaster.
Old 06-13-2018, 01:42 PM
nvr2mny's Avatar
Thanks Shaun, you just saved me a ton of money!
Actually, you CAN have too many!
Old 06-13-2018, 01:58 PM
911 enthusiast
Great upgrade. Less than an hour to do both sides. The passenger side was in slightly better shape, but not by a lot. Plastic pieces were pretty gnarly after 30+ years.
Old 06-13-2018, 05:54 PM
pookie's Avatar
Good info. Thanks.
1976 911 S Targa 3.2
Old 06-15-2018, 05:26 AM
theiceman's Avatar
might be a good idea to mark off with a temporary marker where they go on the body before removing them . Will make alignment easy.
Old 06-15-2018, 07:21 AM
Mark Salvetti's Avatar
So has anyone found a reasonably-priced triple square bit set? I've found some online, but they all seem to use 3/8" drive for the 12mm size, and I would prefer 1/2" (for flywheel bolts).
Might have to just get the 12mm separately.
Mark
1979 911SC Targa
Old 06-15-2018, 07:45 AM
theiceman's Avatar
I got a separate one for mine Mark .
A "good Bit of kit" as the English would say .
it's a Hazet 990
Old 06-15-2018, 08:04 AM
Thanks, that does seem to be the way to go.
Mark
1979 911SC Targa
Old 06-15-2018, 09:05 AM
