High Life's Avatar
Oil in the heat exchanger.. Can I flush without removing?
I finished a valve job and head nut re-torque job and I did not drain the oil first... I did however let the oil spill out into a pan after coating my exhaust and heat exchangers over night..
So I now have a puddle of sort inside the heat exchanger on the drivers side.. Ive spent a couple of days trying to "burn it" however I just finished a 45 minute (30 miles) ride that doesnt seem to do much but make me dizzy..
Here is what I see after the ride - oil is coming out of the seams..
I have no significant oil from the top, I didn't have an issue before, I don't have oil leaking from valve covers, so I fairly certain its from the overnight leaking and seeping into the exchanges..
Can I pull the two hoses from the top of the heat ex-changer and flush (when engine is cold) with a garden hose. i.e Pour some non flammable de-greaser sit and then hose it?
1981 911SC
Old 06-13-2018, 05:55 PM
Sure you can, no problem. Just rinse really well, as whatever residue is left over from the de-greaser will make its way into your cabin when you turn on the heat later on. Use Simple Green or something similar.
'87 Carrera (3.4L)
'07 Boxter
Old 06-13-2018, 06:25 PM
After the clean out, leave the hoses off the heater flap end for a while until everything burns off.
Rutager West
Old 06-14-2018, 02:11 AM
High Life's Avatar
Thank you..
I had a quick thought this morning while disconnecting the hoses..
What would be the harm in drilling a 1/4 hole in the lower back portion of the heat exchanger to facilitate draining..?
I have the SSI heat exchangers..
1981 911SC
Old 06-14-2018, 11:08 AM
Originally Posted by High Life View Post
Thank you..
Another option:
Remove air shroud hoses, then pour a solution of water-based degreaser into the heat exchanger. Whether single or dual out, the sheet metal formed around the exhaust pipes isn't water tight.
SSI HE:
Agitate with short spurts from a garden hose (don't overdo it), then use a shop vac or compressed air to remove excess liquid. Repeat. Run engine to evaporate the remaining moisture.
Sherwood
Old 06-14-2018, 11:48 AM
