vansicklenmi's Avatar
My 915 she go POP!
I posted this on Rlist so repeating here.
After three complete rebuilds in less than two years, my 915 broke at the first auto-x post rebuild. It has a new 1st, 1st gear shift rod and shift fork. New GT gears 2nd and 3rd gears. Every possible WEVO billet upgrade, a Quaife diff, and 7/31 RP. Oh yeah, attached to a 993 varioram 3.6.
So I rolled away in 1st, for slow sighting lap, shifted to 2nd, dropped the clutch and PO, no drive! The shift lever is stuck in 2nd position and will not come out. But ZERO drive. None. I coasted off the course. No sounds, no drag, no nothing. Clutch in or out makes no difference. No drive whatsoever.
Later, with the shifter lever flopping around and in "neutral", and no gears available, now it won't roll the unless clutch is depressed.
No noises, no clunks, no leaks, no drive. I have not tried to restart and move as it now in garage and fear it jump into backwall if started.
Any clues on what might have happened? It's coming out AGAIN and will be taken apart. Maybe even drop in an 8:35 R&P. The world's most expensive 915!!
'75 Carrera, It's stock, I swear, scouts honor!
Old 06-13-2018, 06:02 PM
puddy's Avatar
Sorry to hear that! I've beat on my 915 for 4 years with 355 rwhp and still works great. Your tranny sounds cursed. I'll offer $500 to take it off your hands! 😜 I'd like to start to prepare a new tranny for when mine finally goes pop!
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 06-13-2018, 06:10 PM
Sboxin's Avatar
It sounds like a shift fork came loose - - maybe take off the bottom cover and take a look inside ? With all the work you have done on it must be something simple.
We broke a tooth of R/P and it slide forward into the 5th/reverse area and locked up the shifter . . . some weird stuff sometimes . . .
Regards,
Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 06-13-2018, 07:50 PM
Jiu Jitsu Grappler
Rodsrsr's Avatar
It sounds like a shift fork may be mis-aligned for whatever reason, but the 7:31 coupled to a V-Ram 3.6 is rolling the dice. I run a rebuilt 915 with an 8:31 coupled to a turbo 3.2. I never do launches in 1st and even kinda baby 2nd. 3rd gear is the sweet spot. So far so good and its been close to 7 years. The torque from your 3.6 can pretty much break the 915 at will. I cant imagine the torque with that motor and a 7:31.
No Gi No Problem
Jiu Jitsu Grappler
1976 Turbo Coupe 3.2
2009 Carerra S (997.2)
Old 06-13-2018, 09:51 PM
Bill Douglas's Avatar
3.6 at one end and grippy tires at the other... Yep. somethings got to give.
see www.lyallbaybeach.co.nz
Old 06-13-2018, 10:04 PM
madcorgi's Avatar
Yikes--that truly sucks.
Let's hope it's something simple.
Not to derail, but is a 7:13 the same as a 4.43 ratio? And would an 8:31 be a 3.88?
Old 06-13-2018, 10:30 PM
'76 911S 3.0's Avatar
Correct. Some good info here if you are curious:
915 TRANSAXLE SPECIFICATIONS-GBOX Transmission
Sorry about the misfortune OP, hopefully it's something simple and inexpensive to fix!
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 06-14-2018, 09:02 AM
rkeele's Avatar
915 trans. trouble
the 7:31 r&p will become a problem with a 3.6 My friend blew up 2 7:31 r&p's with a 3.2 it's just not strong enough! go with 8:31 maybe a GT racing 7:31 might hold up better but that's $$$$
Old 06-14-2018, 10:44 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Send a message via Yahoo to KTL
If the 7:31 R&P broke badly it'd make some noise on the roll. Speaking of the final drive, why is the 7:31 needed when you have the extra torque of the 3.6?
I would agree that it's a shift fork issue (or something broke and then disrupted the main shift rod action) and you should take off the bottom cover to start. That bottom cover is what transfers the movement of the main shift rod and then relays the movement to the individual shift rod "paddles" Gordo2 here on Pelican made a nice video showing how that bottom cover gate/fork interacts with the main shift rod
https://www.youtube.com/watch?v=LLEWjNRjJTI
I wouldn't be surprised to see the gate knocked free from the bottom cover. Not uncommon for those studs to pull out of the cover
Kevin L
Present: '86 Carrera, '79 911SC widebody conversion rolling racecar shell
Past: '87 Carrera
Old 06-14-2018, 12:02 PM
madcorgi's Avatar
Thank you!
BTW, I meant 7:31 not 7:13 in my question.
Old 06-14-2018, 01:35 PM
subd
81 SC 3.6 conversion
06 Cayman S
16 4Runner trd pro
A lot of mountain bikes
Old 06-14-2018, 02:58 PM
gearhead
Just don't send them your gear box. They are the MM of trannies.
Old 06-14-2018, 03:26 PM
Brando
quattrorunner's Avatar
Wow. watching to see what happened.
If I were to guess, you have a broken 2nd gear and it's lodged a shiftfork somehow. I only say that because one time when my 2nd gear broke that's how it behaved as well..
Turbo powa!
1977 911s. it's cool
Old 06-14-2018, 04:26 PM
Chain fence eating turbo
Do they paint the axle flanges red? 😂
Old 06-14-2018, 04:29 PM
Bill Verburg's Avatar
i don't see the 7:31 w/ 3.6 vram either
even the SC/RS used an 8:31 on their boxes, top speed on the optional gear stack was only ~130mph, spread was ~40 to 130 w/ 5 pretty close steps, the short steps are what makes these attractive
Bill Verburg
Old 06-14-2018, 06:13 PM
The 7:31 was already in the car with the 2.7 and we discussed switching to 8:31 extensively. But since itís no longer a track car, itís a huge hoot on the street. But we knew the 7:31 was the weak link.
Maybe drop a 8:35 in (not a 8:31) to get the strength but keep the low speed snap.
It goes fast enough to not top out at CODA. (Yes, I did take it back to the track ONCE. Come on Itís a F1 track!) Managed a 2:32 in street car with stock seats and no harness! Embarassed a few 997s, and 991s.
Old 06-15-2018, 03:57 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I put 45,000 miles on an early mag-case 915 with a mildly tuned 964 (chip, light flywheel, Supersport cams, 993 headers) and never babied the car....
A properly built 915 is able to handle the 3.6 power just fine. Itís not a drag-race or speedshift setup but once in gear itíll handle power
I put the later diff cover, a single bearing retainer and the later input shaft in. Other than that itís stock. The input shaft is a known weak link and my original one eventually lost part of its teeth. But nothing catastrophic. I replaced it before the box grenaded.
I agree that something came undone in yours. Maybe a gear broke, or the shift fork gave or something of that nature. Take the shift fork cover off and see what is going on.
Ingo
'74 Targa 3.6 (not stock ) - '01 C4 (almost stock) - '00 ML430 (stock)
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2 - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-17-2018, 10:46 AM
^^^ What tires do you have on the 915/3.6 targa ?
I can't afford that.
Old 06-17-2018, 11:03 AM
ischmitz's Avatar
225/50/16 on 8 inch - wonít spin unless itís wet....
Old 06-17-2018, 11:08 AM
PRO Motorsports
Tyson Schmidt's Avatar
Sounds to me like the 1-2 slider exploded.
Is it the late style hub and slider with asymmetrical teeth on 1st?
R-Gruppe member #382
'69 911E coupe' 2.7E MFI (retired 911-Spec racer)
'72 911T Targa
2004 GT3
Old 06-17-2018, 07:02 PM
