daltvater's Avatar
Brake Caliper ID Help
Looking for a bit help from you experts. Trying to fit brake pads to these but not sure what brakes I even have. I ordered brake pads for a 1995 993 Turbo setup but the rear pads Pelican sent are too big. Wondering if I don't have 993 Turbo brakes???
Thanks so much!
Dan
Front...
Rear
Old 06-13-2018, 08:03 PM
Bill Verburg's Avatar
Thanks so much!
Dan
Front...
Rear
they are not 993t brakes, 993t rear is the same caliper as 993 or 964RS or 964 3.3t front
does the front 993t pad fit your front? If it does the front is a 993RS/993t front aka 'Big Red'
Looks like 964RS/964t(but it's hard to tell from the angle) if so the 993t rear pads should fit them
the rear could be 993 rear or plain 964rear or even 964 3.3t rear, they all use the same pad though there are differences in the piston size and width. These all use the 3.3 930 pad.
Here's a pic that shows the pad differences
front to back
3.3 930 f/r, 964front(& rear w/ 4piston rear), 993rear, 965r, 928 r
993f, 964t 3.3 f, 964RS, 993tt/RS r, 928S4 f
993RS/tt f, 964t 3.6f, 928GTS f
Bill Verburg
Old 06-14-2018, 04:49 AM
daltvater's Avatar
Bill I swear you have answered 10's of questions for me over the years. Not sure what I'd do without your help!
So the 993 Turbo front pads fit mine so I must have Big Red's in the front?
Here is a picture of the rear pads that I removed. Looks like I just have plan old 993 rears??
Thanks Bill!
Old 06-14-2018, 12:53 PM
Thanks Bill!
Possibly
there were 3 different rear and 1 front caliper that used those small pads, not counting the 930s
964 rear have 28/30mm pistons and narrow throats, it takes some work to get them on 28mm thick rotors. These should not be used w/ big red fronts due to bias issues
964 front have 40/36mm pistons and are designed for 28mm thick rotors, but again due to bias issues should not be used w/ big red fronts
993 rear have 30/34mm pistons and while not the beast paring are at least ok for use w/ big red fronts, like the 964 rears it takes some work to get them over 28mm rotors
964t use 30/34mm pistons and are designed for 28mm rotors, these are the best choice(of the small Brembo calipers) for use w/ big red fronts
Bill Verburg
Old 06-14-2018, 02:29 PM
daltvater's Avatar
Originally Posted by Bill Verburg View Post
Possibly
Bill, turns out I have the 993 rears. The car is heavily biased towards the rear brakes however. The shop said they can install a brake bias for a few hundred bucks to fix it. Curious what you think about that?
Dan
Old 06-18-2018, 11:58 PM
Dan
BS
993 big red front(993RS/tt) w/ base 993 rear is functionally what was used on 964 3.6T
bias is 1.659 compared to a stock say '83 SC which has 1.491
I have 993RS on both of mine w/ 1.426, this is getting down to where you might think about a p/v though it's still not at all necessary.
Why do you say that there is too much rear bias?
Bill Verburg
Old 06-19-2018, 04:44 AM
