-   -   Hi-Torque Starter Upgrade Question (http://forums.pelicanparts.com/porsche-911-technical-forum/999504-hi-torque-starter-upgrade-question.html)
Guvnor 06-13-2018 10:59 PM
Hey guys- I’m looking at getting the WOS Performance hi-torque starter but it seems to only have one terminal for the ignition wire to connect to. The SC with CIS needs two terminals with the second sending power (not sure on voltage) to the cold start injector during cranking.
Is there an easy way to wire up a jumper for this or should I stick with the OEM type starter?
Litle brother 06-14-2018 02:14 AM
Hi Guvnor.
You just connect both of the thin cables to the same point on the leight weight starter.
I have done this my self for just a couple of days ago, its easy to do and I am very happy with the result. Now I can use a much ligther starter battery also, mine now 44Ah and 350 CCA.
I saved in total approx 20lb !!
See this article:
https://www.pelicanparts.com/techarticles/911_starter_install/911_starter_install.htm
Mark Salvetti 06-14-2018 04:52 AM
You can buy piggybacked spade terminals so you can mount both wires. See post 23 in this thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/424087-high-torque-starter-install.html
Mark
Guvnor 06-14-2018 06:37 AM
Thank you gents! Ordered a pack of 25 from Amazon for probably less than one would cost at the local auto parts store.
http://Ancor 210613 Marine Grade Electrical Double Male-Female Adapter (25-Pack) https://www.amazon.com/dp/B000NI5D92/ref=cm_sw_r_cp_tai_i_v4MiBbHN6TD0R
mikedsilva 05-03-2019 04:46 PM
How are you liking the starter motor? did you get the WOS ?
Looking to get one for my 911.. cannot find much reference to them anywhere...
