<insert witty title here>
Christien's Avatar
Fuel level sender gasket - cork or rubber?
I had a rubber gasket on mine, replaced it with a cork one which is now cracked and leaking a bit. Is there any advantage to the cork gasket? Seems a bit fragile to me. I'm considering just going back to the old rubber one, though that's leaked sometimes, too, so maybe I'll just make one...
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 05-15-2009, 04:14 PM
Make sure you use a fuel compatible material. Fuel will dissolve most rubbers. (Don't ask.)
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 05-15-2009, 07:09 PM
Recreational User
porschenut's Avatar
Rubber is what came on mine, an '86. The tank is out of the car right now and I bought a new cork gasket for it. The original rubber one is in good shape though, so I can't decide which one to use.
Old 05-15-2009, 08:23 PM
the rubber is same gasket that can be used on oil tank sender.
rubber is an up-grade
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-15-2009, 11:41 PM
mine was rubber and I put it in dry, no leaks
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-16-2009, 10:41 AM
GWN7's Avatar
Use nitrile rubber for the gasket. It is resistant to oil & gas.
Bunch of old cars
Old 05-16-2009, 07:25 PM
gt3racerich's Avatar
Does anyone have a source for a rubber gasket for the fuel sending unit? I am only coming up with cork.
Thanks.
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant.
Old 06-15-2018, 01:54 PM
proporsche's Avatar
Do not use cork on fuel level sending unit....here is one on ebay for you
320902410359
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-15-2018, 02:10 PM
320902410359
Ivan
Thanks. After messing with it, it turns out that the gasket is fine. The clear vent tube next to the sending unit is the issue.
Anyone know where the clear tubing can be bought? And the size?
Old 06-15-2018, 05:08 PM
McMaster-Carr is 5187K75 yellow PVC 1/2" I.D.X 5/8 O.D. and 5187K44 5/16 I.D. X 7/16 O.D. gas usage rated
1991 C2 Turbo
Old 06-15-2018, 05:19 PM
Christien's Avatar
If memory serves, in the end I used a gasoline-safe gasket maker because I couldn't find a rubber one. And that was still in place when I sold the car 3 years ago with no leaks whatsoever.
Old 06-16-2018, 08:45 AM
