Fuel pump connection
Got new fuel pump with the fuel valve included but don’t see how is the old banjo connection going to be attached to the new pump.
I appreciate your suggestions.
1974 911 coupe 4 speed
Old 06-28-2018, 04:58 PM
Registered Minimalist
75 911s's Avatar
You need a cap from Len, boxtergt, once you put the banjo on the new pump.
Alternatively, you can remove the check valve fitting, and use the adapter that will fit your stock bolt that goes through the banjo. You may or may not have hot start problems if you go this route.
You also need the rubber boots over the terminals (not shown) and which I added later.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-28-2018, 05:55 PM
The correct banjo bolt is a check valve keeping pressure on the injection.
Bruce
Old 06-28-2018, 07:44 PM
Thank you.
Finding hard time to locate Len.
Old 06-29-2018, 05:18 AM
