Wur fuel line
Hi,
I see some fuel coming down from what I think is the area hicircled in yellow.
I removed it and I see copper washers only at the top, I think if not mistaken there should be one at the bottom.
Is this true?
What size is this washer?
Could it be from anywahere else in this area?
Thank you.
1974 911 coupe 4 speed
Old 06-17-2018, 11:13 AM
Yes two. Part number 900 123 050 20. They are 8.5mm x 11.5mm.
Chris
'75 911s Targa
Old 06-17-2018, 04:07 PM
82 911 SC - Ancora Imparo
Interesting- so if I replace the WUR I should install two new sealing washers? Or if I remove the line between the FD and the WUR to do a pressure test, should I replace the washers? Didn’t even consider that there were washers in there because the only fuel line work I’ve done is replace the fuel accumulator and filter and there were no washers on those.
Old 06-17-2018, 04:35 PM
Thank you
Old 06-17-2018, 05:37 PM
pete3799's Avatar
From the looks of that picture i'd say your fuel leak is at the filter or accumulator area.
Pete
79 911SC RoW
Old 06-17-2018, 06:02 PM
BoxsterGT's Avatar
Porsche Crest
Ayuh, sure looks wet in upper left corner of photo.
Len
Old 06-18-2018, 12:44 AM
