Distributor - help!
Hi
Please be warned - there's a stupid question coming up!
Please could someone tell me if the distributor itself - bottom casing that attaches to the car (not the rotary arm) should move? It is bolted securely, but it moves side to side a little. Is this right, or should it be completely static?
Having restored the rest of the car, I am now starting work on the engine, which is completely alien to me, so I may be asking lots of very basic questions ... Please answer them in basic terms too - it's going to be a very long learning curve!
Both your expertise and patience are much appreciated
Many thanks
Andrew
Old 07-18-2018, 09:45 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Andrew - according to our Catalog Manager (Porsche guru), it should be quite snug in there. He mentioned for you to check the o ring. You should be able to turn it to set the timing, but it really shouldn't be moving at all.
Old 07-18-2018, 10:57 AM
thank you
Many thanks may I ask if I remove the nut and washer on top of the crank case will I be able to remove the distributor easily. AV
Old 07-18-2018, 11:24 AM
John Thompson
Eugene, Oregon
Old 07-18-2018, 01:18 PM
Thank You. AV
Old 07-18-2018, 02:10 PM
