Weber carb jets...
I am converting my '69 912 from the original Solex carbs to Webers. I have read there are certain parts I should swap out; jets, etc. to make the stock new Webers work their best. Does anyone out there have any knowledge about these parts?
Thanks!!
Old 08-21-2018, 03:40 PM
ptrsbtrs
peter leinberge's Avatar
Go to 912bbs and register / search there.
More in depth info on 912
Old 08-23-2018, 10:15 AM
I played with Webers on my 66 912 for a while....i found that there is always a flat spot no matter what jets are used.
The only difference that swapping out jets made was where in the RPMs the flatspot occurred.
This was my jetting - I found an old post of mine on 912BBS:
32mm venturis
55 idles
F11 emulsion tubes
125 mains
200 air correctors
Acc. pumps set to deliver .55cc for two strokes
Also the float level is set as per the Weber manual.
Thanks,
erik.
Old 08-31-2018, 12:05 PM
ken burge
Go to 28 vents. and F7's
Old 09-10-2018, 03:30 PM
