Ball joint installing
I'm not very sure on how install the ball joint onto the knuckle...
Any help would be much appreciated. Thank you, http://forums.pelicanparts.com/uploa...1538441161.jpg http://forums.pelicanparts.com/uploa...1538441196.jpg |
Hello and welcome to the forum! Take a look at the link below for the procedure from one of our site's DIY tech articles. Hope this helps you out. Please let us know if you have any other questions or if we can assist with any part needs in the future.
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/57-Ball_Joint/57-Ball_Joint.htm |
Thank you,
So basically no pressing required. Just set up the ball joint onto the knuckle and tighten up the castle nut to the correct torque. Am i correct? |
| All times are GMT -8. The time now is 08:45 PM. |
