912E tachometer
I recently purchased a 1976 Porsche 912E that had a 911 engine in it. The seller kept his engine and transmission. I plan to put in a 914, 2.0 engine in the car. The tach that is now in the car is an aftermarket type used for the pre existing 911 engine. Can I use a 914 tach with the 914 engine or do I have to find a 912e tachometer. Thanks.
Roland |
912e freak
914 tachometer will work perfect. nice project good luck.
What are you going to do with the 911 engine, oil lines, oil tank, etc..?
Sent from my iPad using Tapatalk Pro |
As I stated earlier, the engine, transmission, oil lines, and oil tank were kept by the seller.
