LinkBack | Thread Tools | Rate Thread |
66 912 fuel gauge issue
Hi Jake,
Take the sending unit out. You can open it up and clean it. Do it in a table as is a careful operation. You will need some spray oil, long needle nose pliers, and a 1" x1" piece of 1000 or 2000 grit sandpaper. 1. Open the bottom of the sender after oiling the center and open the locking washer so that the small nut comes out. 2. remove the small nut with the pliers and then careful open the tabs (4 or 5) and slide the tube out. 3. Look at the unit, there are 3 long thin wires connected from top to bottom and a thicker center rod. Don't touch the 3 thin wires! Grabbing the top metal connector see if the center plastic slides up and down as you tilt it. 4. With the sandpaper sand all the rust and gunk of the center rod carefully without stretching the three thin wires. Spray the center rod and it should slide easy up and down. reassemble in reverse order closing all tabs and bottom washer. If any of the wires are broken the unit is damaged as is too hard to repair and maintain the thin wires tension. It is a delicate but somewhat sturdy unit. that can be used for a long time. PM if you get stuck! Jose Last edited by AirJose; 02-12-2019 at 02:06 PM.. |
Thanks so much for the reply. I will try that this weekend. I have noticed when I keep it over half full it seems to function more frequently (suspect its a sender issue) so I bet your method will get the sender working better . Thanks again!
Jake |
Jake
You are welcome. The tube will look clean but inside it gets a little corroded. To clarify the oil is to be used to assist in removing the small nut in the bottom of the sender with the needle nose pliers and the center rod wile you sand it. Add some clean oil again in the center rod. The center plastic will then slide up and down with ease. It should take you about 30 minutes and the gauge will work great! Jose |
Thread Tools | |
Rate This Thread | |
