-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Glad to have a 912 - Temperature Gauge Reading (http://forums.pelicanparts.com/porsche-912-technical-forum/1033164-glad-have-912-temperature-gauge-reading.html)
johnsonj 06-26-2019 06:07 AM
Added a 68 912 to the garage a couple of months ago which had been sitting (inside) for the last 6 years (only occasionally started).
At some point the car was resprayed, originally it was Tangerine.
Trim has been changed - planning on returning it to original trim.
Rear tires are a bit big - 215/60
Big bore kit, dual exhaust, and Mark Ten B CDI.
Changed the jets (52 idle, F7 tubes, 125 mains, 190 air) and installed 32mm venturis in the Weber 40s yesterday - after setup the car is running great, took it for an extended drive.
What is a "normal" reading of the temp gauge?
I reached the halfway point on the gauge then headed back to the house (my cooling flaps are always open).
Thanks, any information is appreciated.
http://forums.pelicanparts.com/uploa...1561554271.jpg
http://forums.pelicanparts.com/uploa...1561554314.jpg
Prsh356 06-26-2019 06:59 AM
In the middle is normal !
johnsonj 06-26-2019 07:04 AM
Thanks Prsh356~!
