rokemester's Avatar
1968 Torsion Bar Fitment
Putting a 912 back together and the rear torsion bars are 1/8-1/16” proud of the cross tube. This doesn’t seem correct!
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 11-15-2019, 03:48 AM
rokemester's Avatar
...by the way anyone know how to orient pics properly?? All my iPhone photos are coming in 180 degrees off. Frustrating.
Northeast Ohio
1966 VW Beetle, 6V
Old 11-15-2019, 03:50 AM
cmpski's Avatar
The torsion bar should be inside the springplate. Do not pound it in there! If it won't go in easy pull it out and clean both the inboard and outboard splines on both the torsion bar and the car. Sometimes I use a small triangular (3 sided) file to clean any burrs on the torsion bar splines. Don't over file. Be careful. I use a broom handle with a stiff wire brush for the inboard spines in the car then a vacuum with extensions to suck out the rust and dust. I use anti seize on the splines. I used to use axle grease. If everything is clean you shouldn't have to use force.
1959 Auratium Green 356A Super w/ Rudge wheels
1970 Irish Green 914-6 w/2.2S
Current -1967 Bahama Yellow 912 POLO 2cam4 #1
Handles like a 912 and goes like a 911
www.reSeeWorks.com
Old 11-15-2019, 07:18 PM
rokemester's Avatar
Thank you, will follow those directions!!
Northeast Ohio
1966 VW Beetle, 6V
Old 11-16-2019, 08:22 AM
Anyone knows what is the unit on the left with the cooling fins on it connected to a metal pipe?
Old 11-18-2019, 08:38 AM
Smog pump, correct for a 1968 912.
Old 11-22-2019, 07:48 PM
