-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Help I.D. Distibutor Part Number (http://forums.pelicanparts.com/porsche-912-technical-forum/105430-help-i-d-distibutor-part-number.html)
thejoyboy62 04-07-2003 08:39 AM
Hi Guys, have a 912 that needs tune up. I picked up stock Dist Cap and rotor (Bosch) but they didnt fit. So it is obviously an aftermarket of some type. Here is the numbers stamped on the Distributor. Any help to determine what type it is and what the part numbers would be for:
1) Dist Cap
2) Rotor
3) Points
Thanks for helping a Porsche newbie.
69 Soft Targa 04-07-2003 11:30 AM
What are the last 3 numbers on the distributor?
thejoyboy62 04-07-2003 01:35 PM
The last 3 number are 050 (duh) I guest that calls out for an 050 Distributor?
thejoyboy62 04-07-2003 10:26 PM
INFO FOUND!
Thanks guys, just typed the number on the distributor into www.google.com AND bingo got all the info I needed.
craign 04-09-2003 10:02 AM
Pertronix makes a nice electronic ignition unit for the 050, eliminates the need for points.
C
thejoyboy62 04-09-2003 10:15 AM
Hi Craig, thanks. I'm going to go that route after I get it runing straight. Tracked the number all the numbers down for the Dist, cap, rotor and points...anyone need them just ask.
