Unknown headlight wires
Looking from under the car, under the headlight buckets the passenger side of the car has two wires.. the driver side (picture attached) had two wires and another long wire that was coiled up.
Looking to find out what these are for?
Thanks in advance!
Old 04-05-2020, 05:06 PM
Send a message via ICQ to AirJose
Hello,
the wire you are holding appears to be the front fog light wires. You should have 2 wires, a brown(ground) wire and a white with a green line(positive) wire inside that loom. Normally the age of the plastic loom wire cover becomes hard and cracks with time. Check the wires to see if they match what I believe. Don't know what year is your Porsche; please let us know as the wiring changes with years.
Best to you and stay safe,
Jose
Old 04-05-2020, 09:10 PM
It’s a 68 I will check!..
Thank you.
Old 04-06-2020, 12:41 PM
