-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Refinishing Fuchs. (http://forums.pelicanparts.com/porsche-912-technical-forum/108650-refinishing-fuchs.html)
h.beard 04-29-2003 08:48 PM
Refinishing Fuchs.
Can anyone point me to info for refinishing my Fuchs. Kits or instruction. anything would be helpfull.
Thanks, Howard from Vinegar Hill
eki912 05-03-2003 07:44 PM
good advice is available at these pages.technical side.
and try searching through archives , plenty of advice there too.
e k i
Touque 05-04-2003 06:31 AM
here you go:
Fuchs 1
Fuchs 2
Fuchs 3
NY65912 05-12-2003 06:37 PM
Hi Howard, here's a pic of my Fuchs restoration which I'm doing in my spare time from working on the suspension pan project.
See photo
http://www.imagestation.com/picture/...c/fc2927e6.jpg
The flowers and the rim are masked at what I believe to be the proper dimensions. The flowers are about 3/8" exposed, (masked area), the rim is a 1/2" gap between the "wall" and the end of the rim if you hold a ruler into the wheel and let it come across the rim. I bead blasted the wheel, washed it with soap and water and will clean with metal prep prior to priming.
I bought epoxy primer that is supposed to have unreal adhesion to aluminum. I will then paint with Eastwoods satin black wheel paint and clear coat with Eastwood's satin clear. I'll keep you posted on the progress.
Best regards, Mike
Hoffman912 05-12-2003 08:57 PM
howard,
this is a post made on another message board i frequent, about how a guy had his 914 wheels done. they look really good.
http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=9;t=000524
Joe Bob 05-21-2003 03:11 PM
Al Reed, Orange County CA.....cheap and good.
