-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   WEBER IDF 40 conversion help (http://forums.pelicanparts.com/porsche-912-technical-forum/1087811-weber-idf-40-conversion-help.html)
GHA912 03-06-2021 08:35 PM
68 912.. “Weber 40’s”
Just purchased a rennline Weber conversion, got it very close.. idles great.. after I put miles on it.. it loses idle, dies at lights.. stops signs ect. Will start up with a little throttle finesse and go.
Current settings:
50 idle
125 main
200 air
mixture screws one turn out
Idle was set at 1000 rpm
Thanks in advance!
WFBowen 03-13-2021 09:19 PM
You'll probably need to adjust each idle screw separately for fastest/best idle. If that doesn't help much, definitely check your float levels and make sure the carbs are synced. If you're running a vacuum advance distributor, check that it is getting its vacuum from the correct carb source.
Bill
