dimps8's Avatar
Exclamation Engine oil leaks
OK guys, who has dropped their engine to repair oil leaks. I'm planning to drop this week-end to repair many small leaks that I just can't stand anymore.(these leaks I should have fix two months ago when i had the gearbox/engine out when I replaced the synchro's) Where's the most common leaks? push rod tubes?, sump plate?, cylinder base? come on guys share your knowledge.
Damon Harris
66 912 coupe
Old 06-01-2005, 04:41 PM
Jerome Ryals's Avatar
Don't know if there is a 'most common leak' area but one that is hard to find or see with the engine in the car is the oil cooler seals.
Old 06-02-2005, 03:16 AM
Nige-912E's Avatar
push rod tubes and rocker covers, I always use a sealant on the rocker covers
Old 06-02-2005, 03:33 AM
C. Clark's Avatar
Cylinder head rubbers and pushrod tubes for me, and the crankshaft seal, fan belt end. Valve cover gaskets should be the ones with the metal middle, no sealent needed, breather grommets in the valve covers, thats depending on the year I believe, my 69 has them.
Chas.
356
912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 06-02-2005, 06:02 AM
