-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   High current draw with ignition on & engine not running (http://forums.pelicanparts.com/porsche-912-technical-forum/1090563-high-current-draw-ignition-engine-not-running.html)
florida912 04-08-2021 06:19 PM
Hello 912 Owners,
New user here- need some help in getting my 68 912 running after idle for a few years.
The engine attempts to start but battery ran low after a few tries. While doing some further troubleshooting I notice that the battery draws ~3amps (battery ground side measured) with the ignition switch in the on position (engine not running at the time). This seems very high to me so I start checking for excessive current draw by individually disconnecting certain items and remeasuring battery current draw. Here are my actions so far (I have electronic ignition):
-disconnected voltage regulator leads, no change
-disconnected generator leads, no change
-disconnected starter and solenoid leads- no change
-disconnect both horns leads, no change
-disconnected both parking lamps leads, no change
-removed each fuse individually, no change
-headlamps work but dim
-add on gauges operate ok, voltmeter & oil pressure
-haven't check cigarette lighter yet
Any suggestions are greatly appreciated! Thanks
ejboyd5 04-20-2021 01:22 PM
Suspect an electronic ignition malfunction giving a similar result as one would expect with a conventional ignition when points fail to open and constantly conduct electricity.
