HarryDude's Avatar
Cool 912E Fuel Line help.
I am replacing the old gas tank on my 912E and I figure I should also replace the 40+ year old gas hose as well. Does anyone have a diagram of how the line gets from front to back. Is the gas line steel from front to back and I don't have to worry about it? I don't see anything under the car except for the pump. ANY help would be great.
Old 08-08-2021, 02:45 PM
The line passes front to rear through a tunnel above the floor plan. A steel line can rust through. If you pull the old line out, slip a piece of piano wire through it for a guide before removing it. Its way easier with the engine removed.
Old 08-09-2021, 01:44 PM
Reach out to Len (boxstergt) on this site, he makes replacement fuel lines as a specialty.
The 912e uses a plastic feed and return line in the tunnel. I did a complete fuel system refresh, removing gas tank, tunnel lines and all rear lines. It’s tight up front, helps to have a helper feed or pull from back to front. Rears have a few sneaky routing places, but self explanatory.
Old 08-10-2021, 03:03 PM
BoxsterGT's Avatar
Porsche Crest
Hello Harry-
Here is what I offer for the 912e...
This is a complete Chassis set and Motor set.
Made to order and available as a full set or as individual parts as needed.
Please email me for details.
len.cummings at verizon.net
Thank you csapp05 for your referral.
Len
Old 08-11-2021, 12:26 PM
HarryDude's Avatar
Len, please send me an email address. Your account isnt taking private messages.
Old 08-15-2021, 05:23 PM
BoxsterGT's Avatar
Please see above, and here...
Thank you.
Len
Old 08-16-2021, 04:06 AM
Replacing fuel lines
My main fuel line has started to leak through the rust spots and I’ve patched a spot already. Only half of the line is bad; from the passenger side back. Could I run fuel injection hose from the rear of the car to mid body? I’m confident it would hold but it would have to come close to the exhaust. The car is a 2004 Saturn ion with steel lines.
official website
Old 09-02-2021, 12:13 AM
Tags
912e , fuel delivery ? , fuel line , rebuild help
