-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   912 Engine Replacement (http://forums.pelicanparts.com/porsche-912-technical-forum/1106218-912-engine-replacement.html)
Grant Glascock 11-08-2021 02:02 PM
If a 912 replacement engine was purchased from Porsche in 1969, would it be stamped with a 1969 type number, i.e., 409---- or would it have no number?
Tony V 11-09-2021 08:23 AM
No serial numbers on the 3rd piece of a replacement engine.
Grant Glascock 11-11-2021 11:14 AM
What is the third piece of an engine replacement? Thanks.
Peter Graham 11-11-2021 12:46 PM
... not just a replacement motor/case but every motor;/case it also referred to as the timing cover. Two pieces are the case halves, the third piece covers the crank/cam gears and houses the distributor, fuel pump and some oil system pieces. A replacement motor/case will have no serial number on the timing cover; a replacement case will have a 'K' embossed on the left side case lug, just ahead of the generator stand:
http://forums.pelicanparts.com/uploa...1636663436.jpg
Peter
Prsh356 11-12-2021 10:11 AM
Blank clean !
Grant Glascock 11-12-2021 04:18 PM
Thanks for the education. Since the engine has a serial number (4095137) and there was a number on the 3rd piece under the oil filter that coincides with the '69 model year, I am guessing that the engine began life in a '69 912. No idea what happened, but the engine was replaced in 1969 so basically a new engine.
