Warning lights not working properly
Hi, the warning signal flasher stopped working, which apparently is a common problem. However, I don't know how to replace it. I found a post on this site where someone replaced it by connecting one 4-pin flasher, and a "normal" relay. When I do this, only tge left side lights flashes, and the right side only flashes on the first flash.
Any ideas? Thanks! |
You might try www.912bbs.org
| All times are GMT -8. The time now is 10:34 AM. |
