hiswewonit
1 or 2 batteries?
I would like to know how common, if at all, it is to have 2 12 volt batteries in a 912? Thank you.
Old 06-02-2023, 12:01 PM
The '69 912 had one battery. The '69 911 had two batteries.
John Thompson
Eugene, Oregon
Old 06-06-2023, 03:03 PM
Anytime the 911 was upgraded the 912 recieved the same changes which was from 1966 to 1969. My 1966 912 has battery posts to accommodate 2 batteries.
Old 06-07-2023, 01:25 PM
Thru '68, neither the 911 or 912 had 2 batteries. If your '66 has two dedicated battery boxes, then it has likely had a front clip from a newer car.
John Thompson
Eugene, Oregon
Old 06-07-2023, 01:50 PM
Wrong! My dad purchased the car new and it’s never been in an accident. I’ve since inherited it.
Old 06-07-2023, 02:31 PM
Can you post pictures of the dual battery set up for your '66?
John Thompson
Eugene, Oregon
Old 06-07-2023, 02:51 PM
Do you have a warrant!!!
Old 06-07-2023, 04:53 PM
WFBowen's Avatar
In the interest of factual information, here’s how Porsche’s PET parts catalog helps to clarify it. In diagram #1, you’ll see that all models up to and including 1968 have a single battery. In diagram #2 for 1969 models a change occurs where the models display differences; 912 calls for a single battery while the 911 gets two.
Jess: You state that your car has “ battery posts to accommodate 2 batteries.” You might be referring to an additional grounding stud, possibly for RHD production options or electrical grounding. Either way, the 1969 model year 911 had two batteries and a longer wheelbase to improve weight distribution. The 912 didn’t need this so a single battery was retained.
A few photos would definitely help clarify the discussion.
Old 06-09-2023, 01:27 PM
Bob
The exception in '69 was if it was a euro. My '69 912 targa came stock in Germany with 2 batteries. They are the only ones I've seen in 912's. You might float the question on Samba and the 912 Registry as well.
Old 07-21-2023, 06:16 AM
