dz-vintage's Avatar
Porsche Crest 1966 912 tires
I recently purchased a set of deep six Fuchs. I am wondering what size tires will look best and not rub anywhere. I do not want the current tall skinny look (165/65/15). Thinking 185 or 195/60. Not going for the “kid racer” look at all. Just want something a bit more sporty. Any advice is appreciated
Old 04-08-2025, 10:28 AM
WFBowen's Avatar
The original overall diameter is 25.2” so any tire within a half inch of this will look like it belongs on the car. Lower than this will lower the car, start to effect gearing and speedometer readings and visually create a visual open space in the top of the wheel well.
As long as you stay to an available variant of the original 185/70r15 all will be well.
JMO,
Bill
Old 04-09-2025, 08:12 AM
dz-vintage's Avatar
Thinking 185/65
Old 04-09-2025, 02:53 PM
WFBowen's Avatar
I think 195/65 would be closer at 25.0” tall and would fill out the wheel well.
Of course, your call.
Bill
Old 04-09-2025, 04:07 PM
dz-vintage's Avatar
Lol. Yes I am certainly caught between 185 and 195. We’ll see.
Old 04-10-2025, 04:09 AM
Mr. Merk's Avatar
The Pirelli CN36 in 185/70R15 is the best tire for the job. A period correct design with modern sticky tire construction. The size is right for the car and optimized on a 6" wide wheel. They are available from your local Porsche dealership for less than others are selling them online. Tirerack may also be selling them now, which would be a recent development.
There are also Avon CR6ZZ tires but they're more of a race tire.
https://www.cinturato.net/185-70-15.html
https://lucasclassictires.com/porsche-911-tires/
PS: I have a client with a 66 912 that has 6" Fuchs and 195/65 tires that rub on his struts. In 1968 Porsche added a 7mm spacer front and rear.
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 04-10-2025, 06:31 AM
dz-vintage's Avatar
Mr Merk
Thanks for that last comment. I will be getting 185/65’s. You just helped me with that decision ����
Old 04-12-2025, 04:05 AM
I mounted 185/60 on deep six Fuchs and the look is much sportier without distorting the original spirit. No worries about friction, top handling. The 195/60 also passes, but it is a little more visually filled. Personally, I find that the 185/60 is the best compromise between style and comfort. It just modernizes what is needed
Old 04-30-2025, 01:02 PM
Mr. Merk's Avatar
What tires? Tirerack has zero "performance" tire options available in a set of four, just a ton of "touring" tires.
Old 05-01-2025, 06:45 AM
Here is the link to what Porsche Classic Recommends: https://www.porsche.com/usa/accessoriesandservices/classic/tyre-approval/#Approval-lists
Old 05-01-2025, 07:49 AM
