| Sweetheart912 |
08-18-2003 07:16 AM |
jac912, thanks for the note. 009's have been scorned by Pellow for at least 30 years & and a knowledgeable Porsche engine builder will NOT ever use one because it is in effect a retard unit since it can not deliver advance neded by Porsche engines. Heck, they dont even line up well on install as the condensor hits the oil line. Yet, based on threads seen, there is a "new discovery" of the 009 (must be cyclical as the last discovery was @ 25 years ago & about a year later there were a BUNCH of 356/912 motors being rebuilt). The math never worked for me in that saving a buck on a cheap distributor near term, is worth the huge expense of an overheated engine, burnt piston rebuild in the not too long term....but to each his own.
The 009's appeal because they are shiny, CHEAP and they give the APPEARANCE of working-especially at low end! I have seen and heard of 009 engines burning #3 in less than 5K miles and seldom longer than 10K miles. I have always tried to use only a factory cast iron or replacement 031-you still find them at swap meets cheap and you can send them out for a rebuild & recurve for @$150 American. If that shoots your budget buy a new 050 for @$75 & it will work wonderfully with real decent advance and will not burn up your motor (unless you are a steady long duration redline driver). Pellow made a science of the evils of 009's & so have many of the "noteable" engine builders and old E production SCCA guys. Best of luck on your engine rebuild.
My $.02. Cheers.
