Were's the 912E fuel pump relay
My owner's manual claims it's in the fusebox, but the only relay I have there is the horn relay.
Is it in the engine compartment? Thanks. |
CLYMER book says: Realys for the fuel injection are located on the relay plate at the left side of the engine compartment.
The same book say:If the pump does not run at all,check the fuse between terminals 88y and 88z of the relay.If the fuse is good,measure from terminal 88d to ground ( jumper connected ).Terminal 88d should measure 12 volts.If not,the pump is defective and must be replaced. All this from CLYMER manual , I canīt be sure the info is correct ! Or that it even matches 912E !!! According to this book it should.... I do have the PORSCHE 912E manual , but just canīt find it now... e k i |
