James in SA's Avatar
Send a message via AIM to James in SA
Brake rotor weight
Hi folks
Can anyone tell me the approximate weight of a 912 solid rear brake rotor?
Many thanks
James
Old 08-12-2003, 07:20 AM
HarryD's Avatar
Re: Brake rotor weight
Originally posted by James in SA
Hi folks
Many thanks
James
Hi James,
They weigh about 13-14 pounds each. Any luck finding one closer to home?
Regards,
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 08-12-2003, 02:54 PM
Thanks for that, Harry.
I've found a supplier in the UK, I just need to work out what the shipping costs will be like. Pretty horrendous, unfortunately.
One other option is to take the dimensions and see if there's anything more modern (and readily available) that can be redrilled. Might give that a go if it saves me $$$.
Cheers
James
Old 08-12-2003, 11:44 PM
Green 912's Avatar
Go with vented! Get a set of "M" calipers with the spacer in them and install nice new easy to get modern not oddball vented disks. All parts are bolt on front and rear.
Old 08-13-2003, 02:39 PM
