Engine Cherp
Hello again,
I have a strange Cherp sound coming from the engine, Not the wheels, HA HA. When the car is idling , once in awhile you can here 1 Cherp come from the engine. I also have 1 Oil leek coming from the Main Pulley. Does any one know what that might be. Regards, Andrew. |
Check the base of the carberators. Run your fingers around the bases and you might find a little air leak. I had this problem. Dabbed some oil resistant silicone on the gap and that solved it.
Is it like a (sneeze) out the carb? Mine will do this if the idle adjustment is too lean or if the carbs are not in sync at idle.
Craig |
if they are dell'orto's, they are known to chirp
Im new to the game, this is my first, What is a dell orto???
A third brand of carburetor after Solexes and Webers that will run on our 912s. Some owners are very happy with them.
| All times are GMT -8. The time now is 03:13 PM. |
