-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Trans Type & Serial Number Location (http://forums.pelicanparts.com/porsche-912-technical-forum/126806-trans-type-serial-number-location.html)
ron69912t 09-10-2003 05:56 AM
Where on a 69 5-speed transmisson is the Type Number and Serial Number located?? Can you see it with the engine & transmission in the car?
Thanks,
Ron D
cgarr 09-10-2003 09:24 AM
Its on the bottom center rib, its stanped into the metal, they sometimes get scuffed up a bit, the type # is right at the lowest point and the sn# is towards the flywheel end.
Craig
ron69912t 09-10-2003 10:00 AM
Thanks Craig I'll take a look tonight.
Ron D
ron69912t 09-12-2003 06:23 AM
Craig:
I checked my trans number, it is #5193018 wich according to my manual is a magnesium case. Good or bad? I did not see a "Type" number stamped near this one. But the manual calls out Type 902.300/16.
Thanks,
Ron D
cgarr 09-14-2003 02:11 PM
If you have a 69 it must be the 902/16 it would have the 6:29 r&p which is really nice on the 912's and for the track. The magnesium is liter and uses larger axel (carrier) bearings along with the larger seal. The case should be a dull gray color?
Craig
ron69912t 09-14-2003 05:07 PM
Craig:
That explains why it takes the larger diameter differential output shaft seals.
I never noticed the color as being different than the engine casting. Next time under I will pay more attention to the trans case color.
Thanks,
Ron D
