bought some new brake lines quite a few months back - also just bought a fancny/schmancy Motive power brake bleeder so I could bleed brakes without my wife's help...
filled the bottle with a couple of gallons (well, maybe a liter or so ![]() ![]() There is a little tube sticking out of my floor under the trunk where ALL the brake fluid was forced out - thankfully I started this as a 'test' with my crappy regular dot4 fluid and not my ATE blue. Anyways, why didn't I hold pressure, and why did it come out of 'that' tube...? anyone else tried bleeding brakes with one of these? Is there some kind of pressure release valve? also, couldn't get my brake hoses off, even with PB blaster. Gave them a good soak, and will probably do so for a few months. Hopefully they'll come off someday...
Troy '89 964 C4 '83 308 GTS QV '88 928 S4 |
Before you pressure the system you have to pinch off the plastic overflow tube on the side of the brake fluid reservoir. Mine is so old & hard I just disconnect it & use a vacuum cap to seal it with since it cannot be "pinched." Works great!
P.S. I think everyone has made the same mistake. |
Doh!
OMG - can't believe I didn't see that... thanks! ![]()
Just did the same thing, couldn't understand why I could hear hissing air and the tyre I'm using for the air source emptied in a couple of minutes. Scared the c**p out of me when I saw brake fluid dripping off of the master cylinder, I'm assuming the overflow runs to just above it!
Wish I had read this thread first! Is there anything that got covered in brake fluid near the master cylinder that can get damaged by the brake fluid? Cheers Bill |
Bleeding Brakes
It matters which direction the bleeder valves are pointed. I seem to recall they need to be pointing out/up but that would need to be double-checked. I gave up and let the shop do it. RC
Thread Tools | |
Rate This Thread | |
