Hi,
I am having problems with my charging circuit. The charge light on the dash is constantly lit, and after checking there wasn't a problem with oil pressure, I have tested the charging circuit. I have drawn the conclusion (with help from the manuals) that either or both the generator and regulator need overhauling or replacing. I'm not very mechanical, so replacement seems the best option ... ... does anyone know where I can get hold of a rebuilt genie in UK? I'm pretty sure its the big diameter one ... Cheers Simon simon@itbliss.com |
First, I would replaced both. Pelican sells the rebuilt generator, gr15x - $126 . Not sure why not reg.(30amp)
You can buy a NEW large dia. generator that will fit. . BugCity is where I bought mine. gr15x 12v 30amp 67-73 $115 . Any VW place should have this part on hand. Stoddards has the reg. for ( $183.30) . Bought mine for alot less ($40), just dont remember where. Brett
PtCruiser 03burb 4Kids Best 356/912 Shop I found on the East Coast: TimBerardelli Racing 703.461.3436 Long and Gone: 610 Boss302 41coupe XKE 240z Sqback 2002 912 Last edited by adot; 09-21-2003 at 10:03 AM.. |
Have you checked the brushes in the generator?
Alan Drayson has a used regulator and lives in Poole adrayson@bmth.ac.uk
Roger Bray Restorations in Exeter do exchange units, speak to Mark.
http://www.rogerbrayrestoration.com/
http://www.912register.co.uk |
Your oil pressure light is the green one,on the right hand side.Your charging system is the red one on the left side.
Art |
