Engine And Or Compnents
HI ALL, TOOK MY ENGINE TO BITS LAST NIGHT TO LAUGH AT THE PIECES OF CON ROD, PISTON, CYLINDR BEARINGS AND SWARF RATTLING AROUND INSIDE! SO ANYONE GOT A SPARE CRANKCASE OR ENGINE? THANKS
E-MAIL ROTHKO1@EXCITE
Old 10-07-2003, 07:07 AM
OK ITS REALY BAD. NO 2 CONROD SHEARED AND DEMOLISHED ITS PISTON AND CYLINDER THEN TAKEN OUT THE CAMSHAFT AND CAM FOLLOWERS! BOTH PUSHRODS SUCKED IN AND DEDRIS TAKEN UP BY NO 4 CYLINDER. RESULT- DESTROYED N04 CYLINDER AND PISTON THEN IMPACT CAUSED CASE TO CRACK ABOVE N0 4 CON ROD 3 INCH HOLE! CAMSHAFT IS IN 3 PIECES, CRANK IS BENT CRANKCASE BOTH HALVES CRACKED. SO ONCE AGAIN, ANY SPARE ENGINES???
Old 10-14-2003, 07:34 AM
check this thread on bay 912, I beleive he is in your country too..
http://www.bbs912.org/cgi-bin/bay912.pl?noframes;read=20381
Craign
Old 10-14-2003, 11:13 AM
chickybok's Avatar
That car/engines in the states...
Rothko –_You know how the best person to talk to in the UK - Andy Prill.
Sounds like you should follow that type 4 route.
Old 10-15-2003, 08:23 AM
