atlporsche's Avatar
the current rumor on the meets is that texas, and the sE will each have their own in the spring...
the joint adventure will happen in October somewhere east of texas and west of atlanta.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 10-23-2003, 07:43 AM
Hoffman912's Avatar
not the best craig, but it works
Harry Hoffman
68' 912 Coupe 'Fritz' burgundy red (6808) | 67' 912 Coupe 'need parts?'
912 Registry charter member #912R0195-C | Early 911S Registry member #2070
http://hoffman912.blogspot.com/
Old 10-23-2003, 07:45 AM
Hoffman912's Avatar
steve, im up for it as long as i dont kill her going from ohio to ga in spring, to ohio to monterey in august, as well as every where in between!
Harry Hoffman
Old 10-23-2003, 07:47 AM
Hoffman912's Avatar
i need to get somthing going on in the midwest though.. this is what i roughly have in mind.. just need the 912ers to come out, and need to plan. some gret senic areas through the apalacians that run through southern ohio, & great drives.
http://www.hockinghills.com/welcome.htm
http://www.hockinghills.com/maps/area.htm
Harry Hoffman
Old 10-23-2003, 07:53 AM
Cool Rings
If you have any experience with rebuilds there is not much you can't figure out. I would suggest the Maestros videos. The hardest part is finding a good machinest and paying out the nose for main bearings, exhaust valves, pistons and cyl. etc. I took my heads off to replace push rod tube seals and thought while i'm this far I might as well re- ring and all of a sudden my case was cracked. At least I know what I have. Good luck and keep in touch. Later DG
Old 10-25-2003, 04:44 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
We can do all the Machine work for and we also have quite a few of the hard to find parts for your motor. Steve
Www.ottosvenice.com
Old 11-03-2003, 04:30 PM
