Exclamation Oil Consumption..say what??
While reading my 69 Owners Manual for the 100th time I noticed the normal Oil Consumption statement which really suprised me. Had no idea this amount of oil consumption was considered normal.
I scanned the page for you to see for yourself.
Fortunately my car does not come close to this oil volume even after 84K miles.
Thanks,
Ron D
RonD 69912T
Old 11-03-2003, 06:32 AM
Jerome Ryals's Avatar
Neither of my 912's (both 68's) have ever consumed anything even close to that amount and I used to put some pretty good weekend mileage on them running from Savannah up to the mountains in N GA and NC (600 to 700 miles roundtrip might be 1/2 quart used and that was usually running them as hard as I could when I could).
Old 11-03-2003, 10:24 AM
atlporsche's Avatar
jeez....mine does.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 11-03-2003, 03:53 PM
abit off center
cgarr's Avatar
Mine used to leak that much #@%&*$
Craig
______________________
Craig
G2Performance
Old 11-03-2003, 05:22 PM
Touque's Avatar
I find that if I'm driving on the highway, I can go all day without hardly burning anything, but with stop-and-go traffic here in Houston, I can easily burn a 1/4 quart or more in a 100 miles...
I seem to remember reading somewhere (could be in my up-fixin der porsche) where Porsche would only consider 912 on warranty work if it consumed 100 miles to the quart... YIKES!
Troy
'89 964 C4
'83 308 GTS QV
'88 928 S4
Old 11-03-2003, 06:48 PM
Morrie's Avatar
I go through that amount in mine, but i attribute it to the condition of the motor.
68 912 Coupe, 76 914 2.0 backdated, 76 912E SR Coupe"
Gone but remembered- 76 911S SR Coupe "The Clown Car", 89 944S2 SR Coupe, 76 912E "Green Rat", 67 912 outlaw, 68 912 Coupe, 87 924S
Old 11-04-2003, 06:23 AM
Dang guys, mines still full on the stick at every oil change...maybe there's something wrong with mine! And thats with the leak I "used " to have on the sump plate....Morrie...heheheh
Kevin,
1969 912
1992 Firebird
1985 Eldorado(SS roof)
1992 Ranger PU
1976 Cutlass(tha beast)
various others in the country for parts
Old 12-04-2003, 12:24 PM
Morrie's Avatar
merry early Christmas.
-M
Old 12-04-2003, 12:32 PM
Yep, thanks Morrie! No more leaky sump plate, now if I'd get motivated and seal the dang generator stand where its seeping, my engine would probably stay pretty dang dry and clean. Of course then I'd have to redo all my sheet metal and make things look nice in there...and oil is a rust inhibitor isn't it?
Kevin,
1969 912
1992 Firebird
1992 Ranger PU
Old 12-04-2003, 12:39 PM
abit off center
cgarr's Avatar
Aircooled engines should always use a bit of oil, make sure your carbs are not dripping fuel down the intakes, I had an old VW, I had to drain a bit of oil now and then, it kept increasing on the stick because of a flooding carb.
Craig
Craig
G2Performance
Old 12-04-2003, 02:18 PM
Heh, yeah I've had that happen on small block chevy's when the seals in the fuel pump go bad, easy way to check for fuel in the oil is to put a lighter to the dipstick when you first pull it out. If it catches fire...you have fuel in the oil. I actually have a SB Chevy blow the valve covers off because of that once...it'll scare the heck out of ya.
Kevin,
1969 912
1992 Firebird
1992 Ranger PU
Old 12-04-2003, 09:39 PM
