Question compression ratios
Sorry for asking so many questions guys but I want to plan out my engine rebuild the best I can so I can do it right the first time. Any help at all is greatly appreciated.
My question this time is, is a 9.5:1 compression ratio (such as that from shasta parts) to high for good reliablity. If not what kind of power should I expect and what would I have to do to ensure reliability.
Old 01-31-2004, 06:36 PM
Touque's Avatar
nope, that compression is not too high at all!
the original specs for our 912 engines were 9.3:1 compression. Given that the shasta pistons are of very-high quality, you should have no loss of reliability. If I had the extra $$ laying around, I'd go for those Shasta's in a second.
I think in Duane's book, he has a setup where an engine with Shasta P&C's, a hotter cam, bursch exhaust should develop around 120-125hp with no loss of reliability. If you don't have his book,I'd highly recommend it.
Troy
Troy
'89 964 C4
'83 308 GTS QV
'88 928 S4
Old 02-01-2004, 09:39 AM
how about 15:1 compression
just kidding
If I ran the Shasta pistons could i use by stock cylinders, case and valvetrain. Also how much are the Shasta pistons w/o the cylinders, Shasta has Emailed me back with their pricing yet.
Old 02-01-2004, 09:49 AM
Touque's Avatar
15:1 would be fun for about a second!
there website is here: http://shastadesign.com/
also, they list 9.25 to 1 as the compression ratio and $695 for the prices without cylinders. Also unless you have a big-bore kit now (which have 86mm bore) you will need the cylinders. Even if you did have the correct cylinders, I'd be inclined to buy the complete set - that's just me though.
As far as case and valvetrain - sure. Just make sure they are in good condition. It is very hard (and expensive) to find non-standard crank bearings. If you think you have to crack the case, be prepared for some issues...
Troy
'89 964 C4
'83 308 GTS QV
'88 928 S4
Old 02-01-2004, 09:58 AM
My engine is already in peices.
Its not really a REbuild but more like a complete build.
I don't think I could afford those piston but they sure sound nice.
Does any one have any experience with honing their cylinders themselves, I have some air tools and a drill press, couldn't I hone my own cylinders with one of those flexible brush things. If not what is a good shop that could do it for me even if I had to ship them.
Old 02-01-2004, 11:21 AM
