-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Installing 050 Distributor (http://forums.pelicanparts.com/porsche-912-technical-forum/152485-installing-050-distributor.html)
cobra-6 03-08-2004 05:16 PM
I went to swap an 090 dist. that came with the car for an 050. When I went to install it, after marking where the 090 sat for TDC, I noticed that the cams on the pinion were way off. When I did line them up, naturally too far off for the car to start. Any tips?, is there something different about the 050 distributor that I need to know?
TIA
69 Soft Targa 03-08-2004 11:17 PM
With the 009 the rotor will point to 4 o'clock with #1 at TDC. You know, rotor points to the notch on the distributor housing for #1.
Here's the difference.
With the 050 dizzy the rotor will point to 7 o'clock.
Just drop the 050 into place, it will engage the distributor drive with the rotor @ 7 o'clock. Rearrange the plug wires on the new cap keeping in mind that #1 is now at 7 not 4.
craign 03-16-2004 11:07 AM
This will help
http://www.356registry.org/tech/maestro/050.html
Craig
cobra-6 03-18-2004 09:09 AM
Thanks for the info. Searching through the archives for setting timing, I've found recommendations for 5 BTDC, ATDC, and 5 ATDC. With 32/34 @ 3000 RPM. What's a good staring point?
cgarr 03-18-2004 10:11 AM
on my 031 I set it at about 0 tdc, that gives me a max of 34 advance at 3500 They say its the total advance you want to really use, I am just trying to find out who "they" are, but it works very well, that 031 is really a super dizzy.
Craig
69 Soft Targa 03-18-2004 11:15 AM
Greetings
The 050 averages 27 degrees advance. According to a recent discussion with Don Marks the concensus for max advance is 32 degrees with the gas available today. Therefore a starting point would be static timing of 5 deg. BTDC, about 1/4 inch to the right of TDC.
Maximum advance of 32 degrees is what you want. Set that and forget about timing at idle.
craign 03-18-2004 12:19 PM
Interesting comments as there are those that swear by setting 33 deg at 3,000 RPM I have never been able to get more than 30 deg and that with doing nothing at idle except to start the car.
Craig
Morrie 04-06-2004 10:40 AM
you can dial in as much or as little as you want. Idle advance is your sacrifical cow with an 050.
Morrie
