newbie 912 valve question
greetings
i just entered the porsche world from the vw world with a 69 912. this is really a pretty simple question but i cannot find it documented anywhere for some reason. unlike the vw, the intake and exhaust valves have to be adjusted to different clearences. which is which? i cant tell which is the exhaust and which is the intake. thanks in advance for your help confusa |
The valve configuration on the 912 is identical to the VW setup. Looking at the 4 valve adjusters the two inside valves are your intakes and the two outside ones are your exhausts. In a stock setup the intake is set at .004" (10 mm) and exhaust at .006" (15 mm) with the engine cold. I usually let my engine cool off overnight and the valve adjustments are done first thing in the morning.
I hope this helps. |
| All times are GMT -8. The time now is 02:24 AM. |
