-   Porsche 912 Technical Forum (http://forums.pelicanparts.com/porsche-912-technical-forum/)
-   -   Lowering front of 912 (http://forums.pelicanparts.com/porsche-912-technical-forum/15476-lowering-front-912-a.html)
GS 03-10-2001 11:23 AM
I'm restoring my 66 912 and since I live close to Robeling in Savannah I thought I may track it from time to time. I needed some info on lowering the front end. Any advice would be appreciated.
Thanks!
Greg
John Walklett 03-10-2001 01:18 PM
Real easy. There is an adjusting screw on each side. It is situated at the back of the transverse control arm, other than that I carn't think of a better way to describe where it is. If you have a work shop manual it will be refered to as the 'adjusting screw'. By adjusting this it will give you about 2-3 inch of travel. But be sure to get your tracking set afterwards because as you lower the car the front wheels will toe out.
