Question Electric fuel pump
Does anyone have any experience with electic fuel pumps? I think my maechanical fuel pump has gone south and I don't want to spend the big $ for a new one. Plus, an electric pump would be VERY nice. I've found one at JC Whitney http://www.jcwhitney.com/item.jhtml?ITEMID=4665 for $45 and I think it would be a good buy. Also is there a block off plate I can buy for the mechancal fuel pump, or do I just leave it in there? Any ideas or suggestions are appriciated!
Joshua Harrison
1968 912 Coupe
[This message has been edited by josh912 (edited 04-25-2001).]
Old 04-25-2001, 08:58 PM
WFBowen's Avatar
Post
Josh: I had great luck with the little Facet pumps on a 356 and 2 912's.
http://www.jcwhitney.com/productnoitem.jhtml?CATID=35749
Quiet, small, cheap, etc. As for the block-off, I think some of the "hot VW" catalog/shops sell a block-off that might fit. Or just leave it in (in case......)
Good luck,
Bill.
Old 04-26-2001, 08:28 AM
Post
Josh:
If your mechanical fuel pump has indeed crapped out, consider gutting the internals, hacking off the top works, and using what's left as a plug. There will be some holes to plug - JB Weld should do the trick.
JAS
Old 04-27-2001, 10:08 AM
Ads912's Avatar
Post
Hi Josh,
If you put in a electric fuel pump, you also might need a pressure regulator. You don't want to put too much pressure to the Webers. CB performance can help you there, also with the block off plate.
Adam White
68 912 Coupe.
Old 04-28-2001, 04:48 PM
