oldbusboy's Avatar
Rear seat belts
I've got a '68 912 and I need to install rear seat belts for a safety inspection.
Does anybody have any pictures of the mounting area on their car. I assume there are stock threads somewhere.. these were supplied factory? or were they a dealer ad?
Trevor
Old 08-31-2017, 05:04 PM
oldbusboy's Avatar
I did get a picture of the belts installed on a '67 912.. I pulled my carpet back and I too have the stock plugs to install the rear belts.
Trevor
Old 09-07-2017, 05:21 AM
pors1968's Avatar
You dont need them for safety inspection.
Old 09-07-2017, 01:55 PM
oldbusboy's Avatar
In BC you do.
Trevor
Old 09-07-2017, 07:54 PM
echecsqueen's Avatar
The 66 does not have available mounting points for rear belts...have any of you put them in? If so, how to you do the inside bolts....they would be almost or into the trans tunnel.
thanks
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 09-16-2017, 10:01 PM
oldbusboy's Avatar
If the mounts aren't there I suspect you would have to have them welded in. You can buy the part at SM: http://www.*********************.com/Rear-Seat-Belt-Mount-911-912-65-68-p24955.html
Trevor
Old 09-19-2017, 05:15 AM
