Turn Signals
It seems my turn signal switch has taken a turn for the worse. The switch will not move either way. It still moves forward and back for the headlight high low beam function. I took the steering wheel off and took the assembly out but, even at a close look I can't seem to spot the problem. The car is a 1976 912E and this part is probably interchangable with the 911. Do I have to replace this part or is there some way I can repair it?
Thanks, John 1976 912E |
Something similar happened on my 67. It truned out that easying some lubrication through the mechanism helped free it up. Just a thought, before you look to buy another.
Alan |
I tried lubricating the mechanism but, it still won't move left or right.
John |
| All times are GMT -8. The time now is 06:43 AM. |
